91 eagle talon problems
ccrowell
Apr 18, 2012
shenandoah, Iowa
i just bought a 91 eagle talon it has a ticking goen on nd has oil down the front a lil nd is leaking antifreeze nd kept dien on me to day idk wats goen on
1. Find out where the oil and antifreeze leaks are coming from. To do this, clean up the area around where you see the fluids leaking and monitor it to find out where it is coming from.
2. Fix said leak. If it is a hose, replace it. If it is a gasket, replace it. Get the idea?
3. Put some effort into this. We can help but we can't fix anything for you. You have to put some effort into it to get any results.
4. Refer to rule #5 in the Before You Reply section, as seen below:
5. Use proper spelling, grammar, and punctuation when posting in our Tech Forums - don't use texting/instant messaging lingo here. This isn't an English class, but we demand that you at least make an attempt or your posts will be deleted. Internet Explorer users should download IEspell or just use Firefox since it has spell check built-in.
This:
Should be this:
I just bought a '91 Eagle Talon and I'm having a few issues. First it has a ticking sound. (When do you hear the sound? Only on start up? While idling? While boosting? All the time? Have you checked the oil level?)
Also it has a few leaks. I have seen oil dripping down the front of the block and it seems to be leaking a little bit of antifreeze. I don't know where it is coming from yet.
Lastly it kept dying on me today. (When did it start happening? How often is it dying? Under what conditions?)
