91 GSX Engine noise question
Lone
30
Feb 23, 2011
Nampa, Idaho
1991 GSX pulled off the scrap heap, repaired, and driven for a year or so. CEL on randomly (no codes), but seems to run fair. Valve cover does leak at the top.
Please listen to this sound after being driven. Thanks.
[ame=http://youtu.be/Pct1oarTSHk]Eclipse Engine Noise - YouTube[/ame]
I have not taken the timing cover off yet, but I did wonder if it was the harmonic balancer. I'd heard (no pun) it made a clicking sound when as they go bad.
Will jack it up and take a listen from below. Thanks
The car made the odd noise after it had been driven on highway a couple miles, then it made that noise at idle. When I started it this evening it didn't make the noise. The voltage output of the alt at idle is only 9 volts, so I am thinking the noise may be from the alt when it gets hot. Maybe the bearings?
Much easier to work on the non-turbo laser :)
I replied in your other post as well, but my thoughts:
That timing belt is rubbing somewhere. I cannot tell from the video, but it looks like excessive wear on the outer edges of the timing belt? How is the timing belt tension (Too tight could cause an idler to fail over time?).
Also, what happens to the noise when you rev it? Does it go away or get louder/higher pitched with the RPM rising?
I think it goes to say that you need to check the bolts holding that timing cover on, if all is well, then the problem is most likely inside of it. It shouldn't be hard to find a rubbing spot on the back side of the timing cover if it is indeed rubbing. Does your timing belt look frayed on the edge at all?
  • Wanted 6 bolt NT water pipe
    • chrisman287
