91 FWD turbo engine in 90 AWD turbo car swap
ckeins
195
3
Jul 12, 2003
Berlin, Germany, Europe
hi,
i got a 90 eagle talon tsi awd with a broken motor. it is definately not repairable. a friend of mine would sell me his 4G63T. it is from a 91 eagle talon tsi fwd. my questions:
does this fwd engine will fit without any problems in my awd?
does this 91 fwd engine run with the 90 awd ecu?
thanks,
christoph
Best of my knowledge it will - In fact I "think" my 90 has a 91 motor in it - There are some ECU - Tranny & Spline differences on the 90 but it's still a bolt-up as far as I know - Certainly use the Air to Oil Cooler & OFH off the 90 on the 91 - I'd make sure the Balance Shafts are out of the 91 before I put it in along with all the other commom sense Maintenance & pre-install checks...
you will need your 90 TB, coil and power transistor.. i believe thats all, if i think of more today ill post it here...i put a 90 motor in a 91 last winter so its still somewhat fresh in my mind :p and like Buck said, use the 90 oil cooler
