Resolved 90 into a 92
If it is just the motor itself then nothing. The electronics are somewhat different as mentioned above, but the actually motor is the same. What parts are you looking to swap?
I'm swaping my 90 motor in to a 92 chassis, thanks for the replies just trying to confirm that's all I need.
Thanks
CAS, '91+ coil, '91+ ignitor, '91-'94 Throttle body w/ TPS & ISC, is this all I need?
Just want to be sure of my self before I get into it.
I know there's also a difference in radiators. Whether it's between 5-speed & A/T or '90 & '91+ I'm not 100% sure. I can tell you though, my '91 radiator has 2 hose barbs located on the lower tank where as my '90 doesn't.
