85psi of oil pres at 3500RPM
gsx5104
Apr 27, 2008
seabrook, New Hampshire
I thought i fixed this problem but a Guss not. The motor was just rebuilt has the Balance Shaft Elimination kit in it. I have ported the oil relief housing a little bit. Maybe i need to do it a little more? But i think a 7k it will deff be over 100psi. I have a gauge with a copper line taped in to were the sender is in front of the engine closest to the front of the car. Oh, and the gauge is accurate.
I blocked off my squirters and did the BCE and my oil pressure is exactly like your stating. I have yet to have a problem with my engine due to the extra oil pressure. I do drive my car and have taken it on several 3 and 4 hour road trips and also go to the track and run mid to high 10s and like I said no problems so far. Keep an eye on it but I think you will be fine.
