2G 7 Bolt Rebuild Guide
1995talontsi
Sep 15, 2014
Prior Lake, Minnesota
Before anyone gets all crazy and says to use the search function, I did. Now that that's out of the way, I was wondering if anyone had any good guides on doing the bottom end. All the threads on here are just people asking for the same as myself. Any help is much appreciated.
It's a rebuild of a block that I picked up to build while still having an engine in the car. My goal is 400-500hp.
Also find a local machine shop with a good reputation to have your block machined. When disassembling look for any grooves or discolorations on the bearing. Any marks on the top of pistons and any if theres any foreign material in the oil pan
I was told it was running when pulled. I've read it cover to cover. Not really much in terms of a guide but helpful nonetheless.
I will be bringing it where the 4g63 builders and nth moto does their machine work. Hot tanked and resurfaced at the minimum.
Just south of Minneapolis. This rebuild is a way off yet as I'm currently building the garage it will be done in.
I just moved to Wisconsin so youre not TOO far away from me. i can add you to a wisconsin dsm page on facebook if you like. They are very helpful and knowledgeable
