cswindel
- 398
- 588
- Jan 13, 2023
Georgia
Ah yes the oil cooler on the ol' 7 bolt OFH. I've been poking around and there are some good options out there. I am really tempted to get the @99gst_racer (VOLK) kit, or at the least their adapter with oil filter relocation. But I am curious based on if anyone has data on this and considering that the OFH has a thermostatic component inside already:
Porting the front side or getting a Front Facing OFH seems to be the routes most take, however, I believe I like to fit square pegs and round holes too much and find a solution through a painful struggle. I believe this boundary can be pushed though because it seems 2g aftermarket parts and just 2g parts in general are on a decline and suffering a bit (or at least a bit more in some areas compared to EVOs and in some cases 1g).
- What is the benefit of getting a Sandwich Plate or adapter that has its own dedicated thermostatic switch?
- Is there a plate out there that will not just fit but be close enough to the thickness of the OEM oil cooler such that I don't need to severely chop the OEM bolt down too far (take out the OEM oil cooler and put the plate in its place).
