Moonlight GSX
- 670
- 144
- Nov 16, 2010
Hagerman,
Idaho
Instead of mixing the 6-bolt and 7-bolt head/block I'm using all 7-bolt parts, and as you know the CAS for the 7-bolt (95-96) has it under the cam gears. My problem is that I plan to have adjustable cam gears but the cam gears obviously get in the way (hence the design of the stock ones)...
So does anyone know if the 1G CAS will work by just matching the wire locations to that of the 2G CAS and running the one off the actual camshaft rather than under cam gear. I'm sure it's been done but I'm only finding the 6bolt/7bolt swaps not full 7 bolts. Thanks guys!
