660's on a FPBigT28?
Lithiumt
Mar 23, 2004
Atlanta, Georgia
Can you use 660 injectors on a FPBigT28? I am worried that I wont be able to lean it out enough in the low end...
You can use them but 550s would be better. you will find that you will have to lean ou the mid upper s-afc settings to around -33 to -35% with 660s..
I'm using the 190(rewired) with "50trim" at 23psi and my car makes around 400+whp. So with the t28 the 190 pump should be plenty..
650's or 660's are good for T28/B16G equipped cars.
You will find that they are BIG in fuel flow capability, and if tuning with a SAFC, Like Paul S said....your high setting will be in the -33 to -35 range.
Some say that having so much air taken away by the SAFC will cause "low MAS airflow signal" CEL's.
Good luck.
gsxtacy
