NordicSaab
- 198
- 26
- Oct 6, 2011
Tampa,
Florida
Hey All,
It is time for me to move on to something new. With that, I am selling or trading my 1993 Eagle Talon. It has been proven to 660AWHP. This car is an animal. Some of you have probably seen it at the Mitty or other events. The car runs and drives and is tuned to run on e85. This probably will be a car I miss. Hopefully I can pass it on to an enthusist (and someone that wonln't kill themselves).
Link to pictures:
Pictures of 1993 Eagle Talon TSI
Modification List:
Stock 4g63 - Recently rebuilt with fresh bearings (<2000 miles)
Stock 4g63 Cylinder Head and Cams
Stock Transmission - Recently rebuilt (<2000 miles)
DSM Link v3 running speed density
GM IAT
GM MAP sensor
ARP Head Studs
Upgraded head gasket
Hawver Intake Manifold
ID2000 Injectors
8AN Lines to Tank
Walbro 455
JMF 8 Gal Fuel Cell
Modified stock fuel rail to 8 AN in and out
T3 Exhaust Manifold
Holset HX35w - recently rebuilt
1600 degree rated AN oil drain
3" Intake Piping
Large 3" in and out intercooler
3" Stainless Steel downpipe
3" Mild Steel straight Exhaust
BC Coil Overs (<1000 miles)
Oil Filter Relocation kit
Oil Cooler
Aluminum Radiator Tank
Aluminum Power Steering Tank
Unorthodox under drive pulleys
Mustang Cobra 17x10 wheels
275 Nitto NT-05 tires (<500 miles)
Welded in 6 point cage with strut brace
Flattened floor area
Gutted front doors
NGR Blow Off Valve
Jay's alternator relocation kit
Custom built radiator
x2 Spal 10" fans
Custom aluminum shroud
Tuned to run on e85
Dynoed and tuned at Tucker Performance in Palmetto, FL
660AWHP @ 42 lbs of boost
Car would pick up another 100+ HP with cams
Silicone Coolant pipes
AEM UEGO
Various Interior Gauges
Corbeau custom mounted seat on slider.
MOMO steering wheel
A/C Delete
Spec Stage 3 clutch
Spares:
6 Bolt Cylinder Head with Cams - $250
6 Bolt Cylinder Head w/o Cams - $200
Transfer case - $200
1 Cobra Big Brake Kit - $300
SFI Aluminum Flywheel - $200
Clutch and Pressure Plate - $50
If I were to keep the car I would make the following additional modifications:
Add doors with crank up windows
New TB with a IAC (Current TB has no IAC, as a result the car does not like cold starts, usually fine once warm)
I am offering the spares for sale separately as well. I am flexible and open to trades of all types, up or down... complete cars, stock, modified, projects, etc. Ask for everything is $6200. Will also sell the car without spares for $5000. Will provide a better price for someone I don't think will kill themselves. I have yahoo so the messaging on here doesnt work very well for me. For questions please text, call or e-mail (813) Area code 4802773, or JustinBragan@yahoo (dot) com.
Thanks for looking
Justin Bragan
Link to pictures:
Modification List:
GM IAT
GM MAP sensor
ARP Head Studs
ID2000 Injectors
8AN Lines to Tank
Walbro 455
JMF 8 Gal Fuel Cell
T3 Exhaust Manifold
3" Intake Piping
Oil Cooler
Gutted front doors
NGR Blow Off Valve
x2 Spal 10" fans
Tuned to run on e85
AEM UEGO
MOMO steering wheel
A/C Delete
Spec Stage 3 clutch
Spares:
Thanks for looking
Justin Bragan
