60-1 Turbo Fuel Upgrade?
4g63telantra
454
Dec 10, 2004
Toronto,
Ill be running a 60-1 soon and just wanted to know will a Walbro 255 fuel pump flow fine for the turbo or should I upgrade my fuel system?
Also have 880's
AEM FPR
-6an Lines from tank
AEM fuel Rail
Should I add another pump? maybe a In-line?
How built is your motor internal wise? With a 60-1 you will be pushing the limit's of the stock shortblock. As far as fuel mods there are a lot of 60 trim's and 60-1's around here and they get by with a 255hp along with a FPR and 750cc injectors. No need to upgrade your fuel rail yet. You can upgrade your fuel line but it isn't a must. That is a mod that hardly anyone does on here. It's not a must but if you have it already you might as well use it. What will you be using to tune all of this as well.
Ill be running the DSMLINK for tuning.
As for the short block I have bore 0.020 9.1 pistons,1G rods arp's, 3layer headgasket.
I hit 92.1% duty cycle on my 720's (that actually flow 720) at the stock 38PSI base fuel pressure and 24PSI/11* max timing with DSMLink.
I'm going to step up to 1000's soon.
