6-bolt trans
adidas_coin
193
Dec 9, 2002
Dixon, Illinois
Which trans is used in the 6bolt in 2g? Does it matter? and also if it doesnt matter which is easier to rebuild, the 1g or a 2g? i have a 1g trans but it needs synchro work. id rather rebulid that one then source a 2g trans. also is the 2g any harder to mount up(if possible of course). ok thats all thanks.
You use the 2g tranny. The 2g tranny has 3 motor mounts on it that you need to connect. The transmission bolts right up to the 6 bolt with no modifications.
Use the 2G tranny, the 1G tranny's are harder to bolt up in the 2Gs, because they have diff # of motor mounts.
