[6 bolt swap] how do i bolt this tb?
squid267
158
3
Jan 14, 2012
Dallas, Texas
The threads on the intake manifold dont go all the way to the tb. how do bolt this on? pics would help me. thanks!
1) Take them out and use bolts.
2) Put a die on the end and cut the threads further down.
3) Put a shit load of washers on the end (not recommended but I've done worse).
Thanks for the heads up on RTV, I thought it was necesary.
Whats the best course of action to remove the studs?
If you use the right gaskets the outside one comes with a built in bead of it. The inside and outside gaskets are different. No rtv needed. Also two nuts backing the stud out is the way to go. :thumb:
