6 bolt shortblock- will 7 bolt parts fit?
Gee-Es-Tee
253
Oct 19, 2004
Atlanta, Georgia
I did a search, as usual, but have come up with nothing (alongside the search not recognizing 1st, 2nd, or '7' or '6'...whatever)
Anyway, my dilemma has been alive and well for a few months now. Since I let my roommate borrow my car, it has been slowly giving me sure signs of engine wear. This is a bad thing since the rebuilt 7 bolt has less than 4k at this time. To tell the story again-- he drove the car, overheated it, and it seized up. Luckily the balance shaft bearings went out and that seemed to solve it, but everyday I am noticing more and more engine noise at high RPM (roughly between 3k-4k rpm) It sounds to be a rod bearing or something. This is definitely a wound from earlier before. I keep my engine oil changed regularly, check it often, and take great care of the engine all around. This one episode with my roommate has just caused another headache.
So I was searching and found some shortblocks for sale. One was from DSMgraveyard on ebay, and it ran for about 550 USD and has everything I need. The block, crank, pistons). If I were to buy this, what exactly would swap over with ease and what wouldn't?
Will the head fit? the oil pump? water pump?
Pretty much- what parts from the 7 bolt will NOT fit on the 6 bolt shortblock?
I know the flywheel and clutch will give me problems, but what about the bellhousing for the transmission?
If this is too much trouble, I will just search around for a 7 bolt shortblock. I just want something soon so I can rebuild my 7 bolt again.
Thanks for any help.
Water pump, oil pump, oil pan, pickup tube will not fit. As far as the clutch and flywheel, the clutches are the same, you will need a 6 bolt FWD flywheel though and you will be fine. The head will fit but you will need to drill the head bolt holes out 1mm to fit the larger 6 bolt head studs.Check this out ,it will help you.
Joe
