6 bolt oil squirters
I don't see why they should be removed since it help with piston cooling. People remove them in 7 bolt block to help raising oil pressure applied to the crank bearings, then reducing the risk of crankwalk. Since 6 bolts are not prone to it, i will leave them in place.
But: i've ran an entire summer abusing the engine and running 20psi with two broken squirters and never had an issue.
