6 bolt CAS problem. need help
goldeninja20
589
3
Dec 5, 2010
Norton, Massachusetts
I have been having troubles with getting no spark and no fuel. Everything seems to be getting powered correctly. Injectors will not fire and spark plugs will not spark. I checked my codes when i was cranking. I got a code of P0335. It reads this code and says "Pending code". I have a obd reader that i connect to my phone. My wiring looks fine, i have double checked 10 times :aha:. I took my CAS and spun it in my hand while it was plugged in, and heard nothing happening. Could my CAS be going? When i crank it the fuel pump is working though. I really need some insight, its getting aggrivating :banghead:.
there has to be someone who knows about 6 bolt swaps
