Sold 6-bolt 2.0L 4G63 Manley H-Beam Rods with 8.3:1 0.020"-over Wiseco Pistons
twicks69
Supporting Vendor
4,315
2,037
Mar 12, 2004
Milwaukee, Wisconsin
I have a nearly brand new, very gently used set of Manley Rods and Wiseco Pistons. Assembled with rings.
29 miles on setup. No problems, bearings looked great still, nothing wrong with either rods or pistons. Just pretty much had dyno time and customer changed directions with the setup and wanted to build a 2.3L instead.
Specs are:
Manley H-Beam 150mm 4340 Steel connecting rods with ARP 2000 rod bolts.
6-bolt 4G63 application
Manley 14021-4
Big End Bore 1.890"
Big End Width 1.115"
Pin Diameter .827" / 21mm
Pin Bore .8281"
Gram Weight 573g
Pistons info:
Wiseco Sport Compact Series
Wiseco 6559M855 / K559M855
Bore 85.5mm
Comp Height 1.378" / 35mm
Comp Ratio 8.3:1
Dome Dish Volume -17cc
Head Port Volume 47cc
Gram Weight 332g
Gasket Thickness: .042" (1.1mm)
Deck Clearance: 0
Block Height: 9.015: (229mm)
Rod 5.905" / 150mm
Stroke 3.465" / 88mm
Material - 2618 Aluminum
Pin size - 0.200" wall
Pin Diameter: .827" (21mm)
Piston Rings: Wiseco 8550XX
Bore (mm): 85.5mm
Top Ring Thickness: 1.0mm
Second Ring Thickness: 1.2mm
Oil Ring Thickness: 2.8mm
Oil Ring Tension: Standard
File Fit: No
Gapless: No
Top Ring Material: Steel
Top Ring Facing Material: Gas nitrided
Second Ring Material: Cast iron
Second Ring Facing Material: Phosphate coated
Oil Ring Material: Stainless steel
These were about $1000 new.
I am asking $650.00 including shipping* and Paypal fees*
* = For USA customers; if international, pricing is based off of $615 + actual shipping / 4.1% Paypal fees.
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
