5bolt Turbine Housings
b-morr
190
Jul 24, 2007
Aurora, Florida
Probably a stupid question, but I've never ran anything but mits turbos. I'm looking into getting the PTE T3 57Trim turbo, it says it has a 5 bolt turbine housing. Does that matter, will the 4bolt o2 housing still fit to it?
Will the 4 bolt O2 housing fit the 5 bolt turbine housings...... hmmmm......
Will a square block fit in a round hole? :ohdamn:
I just figured you might not utilize one of the holes. So would I have to get it with a mits housing?
Either get a DSM hot side (DSM inlet / outlet) and bolt it up to your housing. Or get the T3 / 5 bolt (or v-band) and get a new o2 housing.
I can't really help you there because I use DSM hot sides only.
Tom
