51lb/min@ 7900RPM @ 20PSI.. 50trim Maxed?
BlackHawkAWD91
94
Sep 7, 2004
Charleston, South Carolina
Hey guys, first day out playing with DSMLINK yesterday. After getting things dialed in at 20 PSI, wideband reading 10.8-11.1 from 4.5-8k. Timing at 15-16 degrees from 4.5-8k.
At 5500 - 38.1lb/min
6000 - 42.2lb/min
6500 - 43.6lb/min
7000 - 48.9lb/min
7500 - 49.0lb/min
8000 - 51.0lb/min
Now last year at the track, on race gas I ran 26-27 PSI, I have yet to run that much boost with link. How much more will this turbo flow? Is it maxed out on pump gas??
Also, if the car was on a dyno, would the power still be climbing since the airflow does?
With the translator you are going to get inflated airflow numbers.
A standard pte 50trim will most likely top out at 49 lbs/min according to the standard To4e compressor maps.
Ditto on the aiflow numbers being inflated. Theres a thread on Dsmlink which shows you how to tun the Maft with either a wideband or a gm 3 bar map sensor to get the right numbers. Its worth a read and its the best way to calibrate the maft.
I looked at the topic title and said to myself "What in the hell?!"... How is it possible you're see'ing 50lbs of airflow at 20psi when I`m see'ing only about 37-38lbs at 20psi on my GT30R ?!...
I see people saying the MAFT inflates the values a bit? Can anyone tell me if my results match to other people's?
I run 66-68lbs a min @ 28psi trapping 126-127mph Its way off My 35r should only be good to 62lbs a minute and I'm sure I would have to be around 40psi to get that :D So yeah its way off,
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
