50 trim
irishgangsta55
41
Dec 12, 2003
hanover park, Illinois
I was just wondering since my 50 trim turbo has a welded wastegate so its closed now 24/7, Do I have to run the waste from the manifold or can I run it from my O2 housing.
Thanks for any information.
irishgangsta55 said:
So if i can undo that weld I can run it from O2 housing then.?
A true turbo expert would be more help here. The clearance is really tight in that area and I wouldnt try it myself. If it is welded than I am assuming it is more effiecient as an externally wastegated turbo and the flapper is too small to work properly internally wastegated.
