50 trim @ 26psi on 92 pump (PIR)
Seems kinda high especially if you are using ALS too? How much boost are you building at the line?
Building about 12-15 psi, 60 foots were usually low 1.7's. The first few runs were a couple 1.6's, my tires were really shot though.
Here is one of my logs, this was a couple runs before my 11.9 but I don't think I changed anything before my computer died.
What kind of launch rpm would you recommend then if you're launching with around 12psi of boost at the line?
Good job, gives me hope. I agree with diambo that you are launching high. I have my stutterbox set at 5250 I believe with no antilag and if I'm not too careful I will rip the tires apart with my 50trim only building 5-7psi. I think you should see what kind of 60ft you can get launching without the antilag.
Same with me only alittle over 5 psi launching' and I have to be careful not to just break the tires lose my 50 trim is a BB and I run e85 with alot more timing then he could ever get away with on pump though... makes me wonder what it would be like to launch with an anti-lag at even higher rpm...
