50 shot on 18g turbo
qwkdsm2
55
Aug 7, 2002
hickory, North Carolina
i gotta question.............i wanna know if running nitrous to spool my 18g is that logical...........like a 50 shot out the hole then cut it off with a adjustible 10psi switch........just to get some lowend power.....then let the turbo do the rest..........will this be safe......
i have fuels mods....255lphhp walbro...-6an steel braided from tank to a SX fuel filter, fuel rail,and aeromotive fpr.....550cc injectors....
other mods
2g manifold
evo III o2 sensor housing
3inch turboback
adfx smic
upper and lower IC Piping
Greddy Bov
SAFC
i just want to know if it will be safe, reliable, and power producing...
can i run a dry kit or does it have to be wet.....is 75 shot the biggest i should use.......please help.....
Same question^^^^
I will likely be workin with the same mods (identical actually)
but with an fp2544.
50 shot wet kit.
On a turbo that small ( sorry ) most people do not use nitrous to spool the turbo, but to aid in power production. If you are AWD and have the traction, I would run the shot all through the gears ( maybe not off the line, breakage could be a problem ).
I ran an 80hp direct port shot with my 18G turbo, Sprayed throughout the gears, spool on that turbo was good enough, I just sprayed when the boost came on which was 3300rpm.
Storm
Would you guys recommend spraying a 50 or 75 shot on a 60 trim fwd? I have all the fuel and tunning mods.
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
  • For sale 4G63 2g/1g Parts
    2g 1g parts
    • rEclipserGST
  • For sale Walbro 255 for 2g
    Selling a new walbro 255 with install kit for a 2g. Prefer zelle for payment but can do paypal.
    • tyvo98gsx
  • For sale OEM EVO 9 Injectors
    Selling a set of OEM pink top 560cc Evo 9 injectors. Had no issues with these and they have been...
    • tyvo98gsx
