4K Max RPM???
TunedupTalon
Mar 4, 2010
Kittanning, Pennsylvania
I've done an extensive rebuild on my 93 Talon. Including converting from an automatic to a manual. Now for some reason the car WILL NOT tach above 4,000RPM. Does anyone know what could be wrong?
my talon is not building boost nor will it let me rev past 3k.
im very confused. at first i thought it was a bad boost leak so i tested it for a good 2 hours. i fixed the leaks i found but still nothing. then i checked my maf and injectors those are both fine. it makes no sense to me. i can rev it very slowly and as soon as it gets to 3k, my boost guage hits 0 and my car dies.
any suggestions?
PLEASE HELP!
you profile showing a NT car, if you made it turbo can you please list the parts and the upgrades that you installed.
which turbo do you have now ? howe much boost are you running etc.
i can see that you made a Custom aluminum MAF housing in your profile ( check this one at the moment it might be your problem)
Yeah, I'm definitely getting full throttle. No, I didn't convert it to turbo. What do you think may be wrong with the MAF?
