4g64 Mighty max rods & Pistons
RMawddsm
54
Sep 28, 2009
Colorado Spring, Colorado
Rather than necromancing an old threads I figure I'll ask my question in a new one. There are the 89-92 6G64 and the 92+.
I've got a 91 MMM and I'm trying to get everything together for a build. I'm currently focusing on the internals. I need to know if I can just buy some forged pistons or if I need to pick up rods too. I found some Wiseco Pistons that claim to be for a 4g64 with 4g63 head. WISECO PISTONS MITSUBISHI 4G64 WITH G63 HEAD 21MM PIN : eBay Motors (item 310161596385 end time Apr-09-10 16:44:58 PDT)
1) Do both of these engines have the big Rods or is it just the earlier?
>>http://www.dsmtuners.com/forums/bolt-tech/149781-4g64-rods-mighty-max-they-big-rods.html
2) Are they 6-bolt or 7-bolt cranks?
>>http://www.dsmtuners.com/forums/stroker-tech/357093-4g64-g4cs-g64b-cranks.html
Edit: found the Piston Information. Still looking for an answer on the rods.
For the future searchers here's the PN for the Wiseco Pistons:
TBA M865 - 4G64 1988-92 with 4G63 Head (21mm pin, 1400HD with .225" tool steel pins)
K564M865 - 4G64 1988-92 with 4G63 Head (21mm pin)
K564M87 - 4G64 1988-92 with 4G63 Head (21mm pin) (.20 over)
TBA M865 - 4G64 1993-01 with 4G63 Head (22mm 1400H.D. with .225" wall tool steel pins)
K548M865 - 4G64 1993-02 with 4G63 Head (22mm pin)
K548M87 - 4G64 1993-02 with 4G63 Head (22mm pin)
I'm almost certain that the Mighty Max 2.4 was a 7 bolt, but you might want a second opinion. My buddy has one, but he hasn't torn it down yet so I can't say for certain.
I was going to suggest checking out mightyd50.com, but apparently it's shut down. It's a shame, there was a lot of good info there :confused:
