Resolved 4g64 crank swap to 63
shshfbdicn
Mar 27, 2024
alburtis, Pennsylvania
I have a motor that had a manley 2.3 stroker kit and I spun a rod bearing so the crank either needs re ground or I need a new crank. I have been considering using a 4g64 crank, does it bolt right up? I realize I might have to clearance a couple spots. And do I need any specific rod bearings to do this or can I use normal 4g63 rod and main bearing? Also would a 4g64 crank match up with manley rods from the kit?
Just make sure it's from a 7bolt if you have a 7 bolt or a 6 bolt if you have a 6 bolt.
It's pretty much a direct bolt up. There is some clearanceing that has to be done to the main cap girdle. This will already be done since it's got a stroker crank in it, but you might have to do a little bit since the OEM crank and Manley crank might have slightly different size counterweights.
