4g63t sohc 8v head gasket options
throwed
Aug 5, 2013
adelaide, Australia
hi all, as the topic stated i have a jb 85 starion narrow body with the 2.0 4g63t sohc 8valve .. id like to change the head gasket to something that will handle the 1 bar boost all day long with no chance in hell of blowing .. can i use the stainless steel cometic head gasket or equivilent for the 4g63t dohc engine?? any input is welcome :) cheers all
christian
will something like this fit my sohc?
Cometic MLS Head Gasket Mitsubishi 4G63 4G63 T Dohc 051" 85 5 MM C4233 051 EA | eBay
cheers
Yes it should be the same as its still the 4g63 block. Just make sure you have a perfect surface on both had and block for the mls. But for what its worth standard arp headstuds with a felpro or mitsu composite hg will take 20+ psi all day.
The stock headgasket with ARP head studs would be more than capable. MLS gaskets are tough, but they require a flawless surface finish to seal.
Running the oriellys felpro head gasket with standard arps 25psi no issues. I pushed my stock head bolts and head gasket to 20psi for couple months before it started to push coolant to btw.
thanks for the replies fellas i appreciate it, im going to rebuild a engine soon so i want to use the best reasonably priced stuff i can :)
cheers
