4G63 in 99 RS?
BFreeman
Aug 28, 2014
Bethalto, Illinois
So a buddy of mine just got a 99 Eclipse RS. Currently has the 420a. He wants to swap for a 4G63, But I told him I do not think it would be worth the time and money. So 1, Would it even be worth it for a 4G63 swap? 2. Would it just be better to turbo the 420a? Any input appreciated.
No. Try this thread. This topic has been beaten to death over and over and over. It would be the same amount of work to put a 4g63 into any car that physically has room. It is not a bolt in affair. You may as well consider an NT 2g car an entirely different car than a 4g63 equipped car because essentially it is.
http://www.dsmtuners.com/threads/gs-to-gst-what-parts.223701/
You will have a hard time doing 4g63 swap into a 420a shell due to motor mount, wiring, different timing side, etc... But if your friend wanted to do a 4g63 swap so bad, tell him to look into the Evo 8/9 4g63. :thumb: They have the same timing belt side, pretty similar to swap it in and much more easier than a DSM 4g63. But I'm guessing the hard part is, mounting, alternator, piping, axles, diff, and what FWD tranny is going to bolt up with a Evo 8/9 4g63 engine, etc.. I've seen a couple of guys done an Evo swap into a 2g 420a shell but will not be cheap, and not easy to do. There was a guy who done it on facebook in Eat Sleep DSM. If it were me, I would just leave it stock, save up money, buy a GSX or GST. A lot cheaper, and still have extra cash left to spend. ;)
I believe there is a thread on here somewhere, where a guy did this swap and used the bell housing side of a trans that had the evo8's 4g63 bolt pattern (3g maybe) and swapped it with the bell housing side of the 420a's transmission. Made it for the most part a "bolt in" affair, because you still use the 420's trans mounts... But still FWD, and probably still expensive....
