Mike 99GSX
- 650
- 2
- Mar 31, 2003
Columbus,
I get 20 pounds at 3600 RPM on pump gas. Thats with the 264/272 cams, VPC/GCC.
Originally posted by JayHass
FYI I gained *80* whp going from a .63 housing to a .82 housing with a 76 trim stage-III turbine wheel and a 50 trim T04E compressor in a .50 housing. Same boost, same dyno, same tune.
Originally posted by MaineDSM
But please, will you SHUT THE HELL up about your experiences with that car and it's turbos and trying to compare them with the DSM experience?
I guess it wouldn't be so bad if you weren't so cocky and self-assured about it.... but you are, and it's getting annoying.
The cold, hard facts are this: DSM'ers run 11s and put down 400whp with .48 A/R exhaust housing.
Please stop treating people who like .48 A/R housings like stupid morons. Maybe 4000rpm is too much lag for them. ,
And don't give me the crap about "manifold backpressure" I have not seen that hurt a car yet.
Try to base your posts on experience with your DSM.
And the cold hard facts are that a .48 housing is too small. (Unless you SERIOUSLY open them up but what's the point then, just get a larger housing) I never said it wouldn't make power I said it makes the wrong kind of power. You are arguing with a Garrett engineer that forgot more than all of this forum combined. I am not only quoting my experience but his knowledge as well.
Originally posted by BlitzMR2
For a little perspective here, I drive a MR2T. Being mid-engined, power accessibility is a big issue. Controlling the balance of the car in and out of corners, having torque available to correct your line in turn, not having a mallet-like turbo come on and hit mid-sweeper and upset your delicate balance, etc, are all important in any car, but are especially critical in a mid-engined car. I still want a huge top-end rush or I'd have stuck with the stock turbo, so it's up to everyone to find the compromise they like. It CAN'T all be simply about HP or we'd drive V8s; there is also character, flexibility and power delivery, peak HP, predictability, racing venue, etc to consider.
How about building a well-rounded, devistatingly fast, agile and capable sports car, able to run an autocross, road course, or 12.2s all day at the strip. That's the whole point, IMHO, about many of the athletic JDM cars, so choosing an .82 doesn't always make sense. Some may be able to drive fast in spite of an .82 on a road course, but is it optimal? Different strokes....
Ah yes. The famous "Garrett engineer". The fact that you take this guys word over people's actual experience says it all.
I have a strong feeling we could line up two identical cars, one with a proven DSM turbo, and one that should be better according to Mr. "Garrett Engineer". The proven turbo could tear the engineer's turbo a new asshole, and you would say their was something wrong with the car.
Actually I agree with what you said 100% but you have the characteristics of the housing backwards I think.
The .82 is actually one of the smoothest regarding boost onset when used on a 2.0 16V motor. It's the small housings that "spike" and come on like a mallet.
The smaller housings have more "on call" power than the bigger housings do. Downshifts are not an option mid-sweeper at 45 MPH, and if you're in 2nd for a tight right hander, you're surely not going down into FIRST for more line-altering power,
I drove had a stage 5 wheel
FWIW, we have stock turbo'd MR2s in the 11s, so HP and small turbos aren't necssarily mutually exclusive, but small turbos do suck![]()
Should be sweet. If it sucks, I'll go to a 63, but will leave the 82 to you DSM studs
I bought a dual Ball Bearing T04E-50, .48 turbine with a Stage 5 inconel wheelShould be sweet. If it sucks, I'll go to a 63, but will leave the 82 to you DSM studs
Stage 5 turbine wheel? How much of a diff. is that from a Stage 3?
Us 2G guys are the only DSM Studs. Women actually *run away* from the 1Gs. This is fact.![]()
Call ITS and see what they say 805-526-5400
