450cc?
mysticfire6602
1,192
7
Dec 23, 2004
Bloomsburg, Pennsylvania
i might be getting a free set of 450cc injectors, what would i need to do, if anything, to modify my car to accept them. please dont ask me why or what im doing to the car, i have plans. just please answer it nicely
Most of the time, when upgrading your injectors you need to add an AFC or Super AFC to be able to over ride the ECU's fuel programming. Your situation may vary depending on your existing setup, but I'm pretty sure you'd have to add one in.
You wil also need the injector resistor pack from the turbo , otherwise you will burn the injectors.
/alfred
mysticfire6602 said:
so how would i go about hooking up an AFC and that resistor pack?
The AFC wires into the ECU wiring harness, and you can get kits to make it easier IIRC. As far as the injector pack, you've got me there. I thought they all had them...
where would be a good place to mount the AFC so it doesnt get a lot af attention. im trying to keep what im doing to my car looking normal to people looking in, no hints of any performance that might be under the hood.
When I turboed my car I used a 90 turbo ecu to control the 450s and 1G turbo fuel pump. I've never used a injector resistor pack, I'm now running RC 750s with no resistor pack. How come I'm not having troubles?
