420a pvc valve question
I put one from the 4g63 on mine. To be honest though, I havent really checked how well it is functioning. It is kind of a PITA to rig it up though.. The OEM pcv is not designed to hold boost and it is also plastic. I opted for the 4g63 pcv because it s designed for boost and is metal.
i have 92,xxx miles on the car. it was replaced at 70k. and i can blow threw both sides and it lets air right threw. i was thinking to swap for a 4g63 pvc valve due to running boost. I'm sure i can make it work.
do you know if the tubes are the same size still?
I ment pcv valve. sorry all these late nights can't think
