420a problems?
EDM95
8,747
4
Mar 25, 2007
amarillo, Texas
Well I went and took a 3rd look at the car, what did I see antifreez coming out the top of the radiator I was like wtf and then I took a look by the trans again and what do I see oil comeing out of the hose driping onto the trans. Then to top that off every spark plug gasket is leaking out oil.:cry:
Why or how come is antifreez coming out the top of my radiator? How do i fix that?
Oil leak from hose pic, Do i need to drain the oil out to change this hose?
The hose is the one on the right going to the transmisson.
How do I remove that hose for the oil flow to the trans? I took off the clamp but the hose did not come off.
use a small allen wrench and shove it in between the end of the hose and the nipple working it around the nipple to break the bond of the rubber from the nipple.
And replace the radiator unless you can find a visible crack. If it blows that end cap off you could overheat and trash your motor and or turbo.
So would I have to drain out the oil, so I could remove this hose? Do you think the oil would leak alot if I don't drain it out?
Well that jb weld did not work, looks like I will be saveing up my pennies for a good radiator.
I took off that hose and just the fluid in the hose leaked out.
