420a help. starts up sometimes and runs for minuts
turbomoe
86
Oct 2, 2007
LINCOLN PARK, Michigan
okay, i looked at all the other threads and nothing helped. my car was driving perfect!
and they it dies out, so i had replaced the hole fuel system, pump filter and lines, call started up, ideled for 20min, got in it to drive it and died, right away, no i only have spark somtimes and my car will only start once a day in the morining, runn for 15 min and then die, and i get no spark, and no power to any of my sensors,,,,
please help
if you could u can cal313.717.5348 or list will check hrly
If it`s a 420A engine(same as a Neon),I ran into this. It sounds like a bad crank/cam sensor. Just replace them both, because they share a common output to the ecu, & are difficult to troubleshoot. A bad camshaft position sensor or crankshaft position sensor will give you that symptom, I would replace them both . . . :talon:
