420a head rebuild
richi77
Feb 26, 2012
elizabeth, New Jersey
well my 420a jumped timing nd im planing on having the head rebuild but i want some one opinion on port & polish with bore TB on a stock block with 8lbs of boost on a t3/t4. Btw its my DD so only want about 250hp nothin to crazy for now.
For the airflow levels that you are running you will not benefit from porting the head or a bigger throttle body. Just get the head cleaned up with new valves and new gaskets and save your money.
I disagree on the TB, get a 60mm, with the intake ported to match, very common good mod for the 420a. As for your goals, isnt hard to hit with a turbocharger, but if you are rebuilding the head, some crower2's with springs and retainers is a solid investment. As far as porting the head, our stock heads flow rather well, unless you can get a hell of a deal, probably overkill.
  • Wanted 6 bolt NT water pipe
    • chrisman287
