420a engine swap, what works?
tiffanddave
Aug 19, 2008
tucson, Arizona
could anyone tell me what years and cars could i get to put in my car I need the motor info. I have a 95 talon non turbo? Thanks!
sure, do a 4g63 if your a master fabricator. You try to do that and you'll be biting off more than you can chew. If you want a turbo, build a good solid 420a motor, then turbo it. But for the money you would spend on that, you could have bought a gst-gsx-tsi....
If you want to keep your car, its just the 420a buddy...
I think the OP wants to know what other cars he can pull another 420a out of. In that case The only ones that I know of that are a direct fit is out of the Dodge Avenger and The Chysler Cirrus...the older Neon R/T had a 420a but I think the Top end is diffrent.
crap that sucks! I called the wrecking yards they said any sebring neon avenger eclipse and talon 95-99 would work, but they don't have any. I just want to stick with the same motor cause it will be my dd
This is the first time I ever heard of anybody asking what other 420As can be swapped in. Usually it's can I swap a 4g63 in.
I guess the op's post is really hard to understand. But the whole swapping a 420a has been beaten pretty bad especially putting a 4g63 into a 420a. Either way just reads Locke's thread.
