420a compression check
JLCustomizing
Feb 4, 2013
Dickinson, Texas
I've read a bunch of different threads seeing whats good and bad on compression check. I did mine, was more on the cold side because my timing is a bit off and I wanted to make sure I wasnt wasting my time changing the timing belt on a bad engine but my numbers were as follows:
1: 159
2: 155
3. 152
4: 151
Seems like I should be ok with this correct?
a stock healthy motor should be around 180 but if your timing is off then that could be why your a little lower and you did it cold. i would put on a timing belt kit if thats what you need then retime it and check your compression again.
Sounds good. I plan on rebuilding a different 420a and tranny over the course of the year as a project and throwing it in maybe may 2014 but ill go ahead and get a belt on it and warm it up and check it again.
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
