420a 20g turbo dyno chart
Rage-Tek420a
98
Oct 20, 2008
South, Florida
I have a 95 eclipse 420a with a Hahn Racecraft turbo kit. With a 20g anyone know how much power these things can hold?
I have made so far 395 HP. With built bottom end, 22 intake and 24 exhaust cams, Megasquirt, 750cc injectors, 3inch Exhaust, Pump gas.
Dyno sheet comming soon !:dsm:
theres no exact or even real ball park number for turbos, it all depends on your tune, engine efficiency and supporting mods, really you wont know numbers until you dyno and tune the car
The boost spiked to 22lbs and fell right away to 15 then krept back to 22... We have not had the chance to finish the boost control settings.... It was late =)~ simple fix but went home.
go to a external gate this will stop boost creep.i was having the same problem. as far as horsepower ive seen 20gs make 500 hp with supporting mods.thats why ive stuck with my 20g i like the driveability as well.im at 25 psi on pump gas with no knock.im trying for 28 with alcohol injection.goodluck
Do you have a dyno chart so I can compare.
