Williamtremb
- 0
- May 29, 2013
Forestville,
QC, Canada
I bought a talon tsi 97 and the engine blow up sooo i bought a 6 bolt engine with supposed 60 000 kilometers on it so i bought a rebuild kit ring,valve seals,oil pump,balance shaft elimination kit,cometic head gasket,acl main bearing,head bolt,acl rod bearing.
my talon already had
Evo III turbo 16 psi
660 injector
255 fuel pump
safcII
Big front mount intercooler
blow off who let the air to atmosphere
piping from different size 1.75-2-2.25-2.5
turbosmart boost controller
2.5 exhaust system with cat and dynomax muffler (i dont know if the cat is a high flow or the stock one)
i think i have a 3 inch downpipe
stage 4 clutch 1700 series
my setup i wanted to reach my 400hp to the engine
EIII 16g turbo 22 psi
660 injector
255 fuel pump
sold the safc for 200$ and get dsmlink v3 lite
bfmic
get the air from the blow off into the piping because i dont have a gm maf
2.5 piping for the intercooler
keep the 2.5 exhaust system because i dont want to see popo in my rear view
external dump tube if possible or keep the stock one
magnus motorsport intake (is it really needed because it cost me really cheap and now i have only the 2g intake mani and the cyclone intake mani)
clutch stage 4 1700 series
would i need something better or something in the 2nd list i dont need really
thank you for the intelligent response
and sorry for my english my first language is french
660 injector
255 fuel pump
safcII
660 injector
255 fuel pump
bfmic
) did the magnus WORTH the 300bucks vs the hp produce?
