40 shot worth it?
VRMAN
634
3
Apr 8, 2003
Daygo, California
Please check my profile for my mods. My good friend and racing partner installed an NX wet shot (60 shot) in his Stealth TT. I have the oppurtunity to purchase an NX dry kit and wanted to run a 40 shot just to help out in those races where we aren't pulling on each other.
What are your thoughts on installing a 40 dry shot? Productive? reliable? Thanks for any info you can give.
NX does not make a dry kit? Unless your talking about an Incognito system which is designed for carb applications.
Nor does NX have jetting for a 40hp shot.
It's fairly obvious you havn't done the research you need to run nitrous so I would suggest you stay away from it because you will only blow up your car then blame your lack of knowledge on nitrous damaging your car.
