TuRBoTaLooN
- 760
- 18
- Apr 27, 2005
Denville,
New Jersey
I've had my CEL on since I bought my car, but it seemed to be running ok. Obviously this is because I"m a newb and don't know how my 95 tsi awd should run. I didn't even notice that my 2g bov was broken when i got it and not holding any boost. I felt a world of difference after installing a 1g that actually held boost. Anyway, I took it to Autozone to get the error codes checked because it is free!!
After abot 15 minutes of convincing the guy that my car was OBDII, he hooked up the scanner and found me FOUR error codes!!
. I was in a hurry to get back to work because I was on my lunch break, but this is what I got from the guy...
1) First code (if i remember correctly
) was P1400, which was something about emissions that I "need to take to the dealer about." I'm assuming this is why I failed emissions at the inspection station on Saturday. (CO was 0.064 instead of 0.050) Not worried about this because I'm getting a new cat-back w/ test pipe setup soon....I hope.
2) Second code he told me was something about the fuel trim that was wrong, but didn't give me specifics on.
3) Third code was something about insufficient fuel supply. Again, that's all I got.
4) Fourth code was something about the idle. The guy said that I'd probably have to "adjust the idler arm." I've been having some idle troubles lately, which I believe I posted in another thread on the newbie forum. Here is a link to that thread . Also, today that problem got worse because the car was idling at 2200RPM!!!
I tapped the gas and it went back down to like 1500RPM, but still...this obviously is a problem!
What I'd like to know is if you guys can help me out in any way. What specifically are these codes coming from, and how can I fix them? The one I'm most worried about is the idle problem. It doesn't always happen, but I'd like it to stop idling at like 2000rpm every once in a while. I am not even worried about the emissions code like I said, but I would also like to know what I can do to fix the fuel problems. I'd appreciate any help you guys can give...thanks!
*edit*: I also just wanted to add that my car is pretty much stock. I have a 1g bov, some free mods, and an mbc. That's all that is done to it to the best of my knowledge. I've only had the car for about 2 months now. If you need more info to help me out, just ask and I'll post it. Thanks guys!!
. I was in a hurry to get back to work because I was on my lunch break, but this is what I got from the guy...1) First code (if i remember correctly
) was P1400, which was something about emissions that I "need to take to the dealer about." I'm assuming this is why I failed emissions at the inspection station on Saturday. (CO was 0.064 instead of 0.050) Not worried about this because I'm getting a new cat-back w/ test pipe setup soon....I hope. 2) Second code he told me was something about the fuel trim that was wrong, but didn't give me specifics on.
I tapped the gas and it went back down to like 1500RPM, but still...this obviously is a problem! What I'd like to know is if you guys can help me out in any way. What specifically are these codes coming from, and how can I fix them? The one I'm most worried about is the idle problem. It doesn't always happen, but I'd like it to stop idling at like 2000rpm every once in a while. I am not even worried about the emissions code like I said, but I would also like to know what I can do to fix the fuel problems. I'd appreciate any help you guys can give...thanks!
Anyone have any tricks or tips on how to get it out??? If not, I just plan on taking it to a local shop to have it done. Then I'll post up on what trouble codes went away.
