4 Bolt rear end, is there realy a difference
c711
Jul 12, 2004
Germany, Europe
Between a 3 and a 4 Bolt rear end is there really a difference between the differntials? Or just the axles, hubs, etc are different?
Or let me say, if I have some 4 Bolt axels can I use my old 3 Bolt LSD with it?
Thanks
c711
gear ratio I believe is different, plus I also believe the 3 bolt is a lot weaker of a rear end. If you do a search on rear diff you should be able to answer your own question.
Ratio is the same,there is only a diffrence between Manual and Auto Transmission.
But has ever anyone tryed to but some 4 Bolt axels in a 3 Bolt differential?
I guess the differentials are the some they only change the axels...
