tstkl
- 3,890
- 78
- Feb 10, 2005
SoCal,
California
so I've been tuning these 1000cc fic injectors for about a week, and finally was able to make a pretty clean 3rd gear pull. My new computer doesn't have a serial port, so I can't hotsync my palm, so I'll just discribe the log.
starting at 2687 rpms with a tps of 99.6% and timing advance of 30 degrees, my o2 volts were .87, with 1 count of knock (just a guess, timing) and ending at 7093 rpms at 25 degrees timing with 3 counts of knock and an o2 volt of .83, (the injector duty cycle is 48.4% with 1944 hz...but thats with the maft.. so thats probably wrong
The reason why Im posting this is because of what I felt while making the pull. The car feels sluggish and somewhat slow from 2687-5k rpms, but at 5k rpms, there is a sudden, extremely significant pull that continues on up until 7k rpms. The first thing I noticed while looking at the logs is that at 5k rpms, the knock count has shot up to 14, and trails off to 3 at 7k rpms. This is weird to me, because the timing advance at 5k rpms is 13, it goes down to 11, then goes up to 25. Upon further inspection, I noticed the narrowband o2 sensor values (btw, I have a wideband, but it stopped working misteriously, I'll be attempting to fix that on tuesday with paul) start at .87, go to .91 by 2906 rpms, and then hit .85 at 4187 and stay there til 7k with one exception. The one exception is that at 5k rpms, 5062 to be exact, they dip down to .83 for a second, then go back to .85. This happens twice more at 7062 rpms and 7093 rpms.
So to me it looks like I need to richen up the 5krpm zone by a very small amount, and lean almost everything else out.
following the injector duty cycle, there are slight changes throughout the pull, which may be due to airflow changes, but may also be the cause of changes in afr.
the whole pull took exactly 14 seconds. 14.000 seconds.
any thoughts as to why when I have the lowest timing advance and the most knock, I feel it pull the hardest?
