3rd gear problem (Please, HELP)
93DE-EZ-UM
57
Mar 24, 2003
Raleigh, North Carolina
After putting in the new ACT2100 and ACT exact light flywheel and brand new throwout bearing, my 3rd gear will go into gear but when I release the clutch, I will grind and pop out. I bled the clutch many times and did it correctly. I also notice the sqeeking noise when I press the cluch in. Can this be a bad throwout bearing? Can a bad throwout bearing cause the 3rd gear to pop out? Another posibility I've searched on here is a bad 3rd gear syncro. But if it's the syncro, why will I be able to shift to 3rd and pop out when the clutch is release? Thank you in advance for replying. :thumb:
Newey
I am assuming that you never had problems with it before? I don't see why the throw out bearing would just affect 3rd gear.
I did have the problem with it before the new clutch was put in but it only pop out of 3rd once in awhile. Now, I can't even get it to stay in 3rd gear for even a second once the clutch is release. More help, Please. :coy:
:cry: Someone,please, help. I'm about to give up on this car. Big money pit. I'm having problem after problem. On and on and on......
sounds like you should have overhualed it when it was out my friend :(
popping out of gear is an internal prob. bad hub and sleeve and or worn out shift rail pins.
