3rd gear grind.... someone help!
NJgsx
90
Nov 11, 2004
mountainside, New Jersey
my friends got a :dsm: 95 talon tsi awd and for some reason when ever i slam third at a high rpm it grinds a bit but still goes into gear it only happens in third every other gear if i shift the same way it just falls right in. does anyone have any idea what this could be?
How high is your clutch petal off the floor before it engauges at idle. What tarany fluid are you using. Also check your slave and master cylinders for leaks. Check under the boot on the slave.
