3bt axle cups (lsd same cups as non lsd???)
90gst_sean
566
10
Apr 9, 2006
Seattle, Washington
Are the 3bt axle cups the same for the lsd rear end as the non-lsd rear end?
I picked up a lsd for my eclipse and cant get the axles installed... the axles that came with, the lsd:)
what a pita. The lsd diff came with axles, but no cups.
What side does the long axle go on?
Are the 3bt axle cups the same for the lsd rear end as the non-lsd rear end. What side does the long axle go on?
From the FSM:
The drive shafts for models equipped with the
limited-slip differential are of different length and,
in addition, the right drive shaft has a two-part
serration; be very careful to install each one on the
correct side.
NOTE: The left and right drive shafts can also be distinguished
from each other by the identification color of boot band C.
Yellow = Left
Bule = Right
;) :dsm:
I don't think that was what he was asking.
As for your question. No you can't use LSD axles with a non-LSD rear diff (and vice versa).
However if you are going from 3 bolt Non-LSD to 3 bolt LSD, the cups should be the same.
If you are going from 3-bolt non-LSD to 4-bolt LDS then that won't work either. And if you are (and get the cups), make sure you are getting the right one. You can't mix Auto rear-end with Manual Trans (and vice versa) the final gear ratio's are different.
