3" GM Blow Thru set up?
Drifter27_04
335
Feb 13, 2005
Winston Salem, North Carolina
Does anyone have pics of there 3" gm maf and translater setup? If install yourself how much of a gap I should cut out of the IC pipe? If anyone with a Burschur FMIC with the 3" GM blow thru set up would be of great assitance. Please someone help. If anyone know of a tech article they can direct me to would be great as well.
sane me your email and I can send you pics of mine. It also allowed me to setup a true cold air system intake. mark
xLuciusx said:
Thank you for the pic. The setup you have was one idea I had but was not sure of it. Since I seen your pic I may go ahead with it. I also have a question to point out and that is your throttle control box; i notice the wears are going up towards the firewall. How do you have it mounted I am wanting to relocate mine as well to make more room than where it is at now. I am also running i the problem where it is somewhat interferring with the gm maf.
Once I get everything connect I will post some pics of the results :thumb:
My MAF is just before the elbow like most. What I have is the translator mounted in the cabin right below the radio sitting on an unused ash tray! Great NOT to have to get out for adjustments! Mark
DsMWookie said:
that is the cleanest ####ing 4g63 i think ive seen
Dunno if yer talkin about my setup, but actually its a 4G64 boosted engine. :D
I made my own extension and have the control box in the center console storage
box for easy adjustments...
Yah man mad props on keeping that bay clean im trying to get mine their. :thumb:
91AWD talon1 or whatever ur name is....your throttle body pipe i believe is supposed to be rotated more downwards. That looks like an SBR one and it should be going down just barely running over the shift linkage. Unless you just wanted it that way.
