3 dash lights???
boost1995
May 29, 2011
wausau, Wisconsin
Ok i have a 95 tsi talon and today my battery light, brake light and washer fluid light all came on at once. I have check every ground possible except under the dash. Has anyone had this problem or does anyone know the reason and solution? Thanks in advance!
Ok will do but if my alt was bad my battery would die during night driving whrn i run all my power. My lights dont even dim
Ok gentleman i tested the whole charging system and it came back perfect so then i checked the fuses under the dash and hood and theres not a single blown fuse. I checked and rechecked every ground possible and they are all tight. I have no idea were to go from here. Should i pull the cluster? Is there a ground or something back there that may cause this?
Also what i was assuming was my washer fluid light looks like a castle? I read somewhere that was a abs light but i dont have abs on my car. Any ideas are more than welcome because i am stumped.
Coolant is full? Overflow is between hot and cold marks. Mitsubishi and there crazy use of pictures. I allways though that was the light for abs not working. Because it has allways been on on all my mitsu vehicles that had abs, which I had disabled.
Yes the coolant is full and it also seems as if the lights are dim. If i pull the e brake up the brake light actually gets brighter.
Got a voltmeter? Turn the car on and check the voltage. It should be over 14 volts.
Brand new? you do realize they half ass clean them and replace what caused it to fail the first time and send it out. I've head 3 alternators go out cause of their half ass rebuild methods..
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
