2g's have high or low impedence injectors?
doodie
1,025
Aug 11, 2002
Brooklyn, New York
I have a set of RX7 550cc's high impedence injectors. I've put them in the car and I have an SAFC. The car ran great for an hour and a half or so then it ran like poop after that. Theres a slight misfiring at idle and the idle is all over the place. I was wondering if the 2g's uses a high impedence or low impedence injectors like the 1g's.
Both 1G and 2G have low impedance injectors (Peak and Hold) which is the same as what the RX7 runs. Typically any car with 400+cc injectors will be Peak and Hold. The problem with putting used injectors out of a nother car is if they sit for a really long time they can become cloged up with old gasoline that has partially evaporated or was really dirty from the car sitting etc and the injectors are really clogged up.
Basically you should never put injectors from another car in yours unless they came out of the car running (and it was running good) or you have had them cleaned properly.
