Resolved 2GNT Wire colors for the Park/Neutral Safety & the Trans Range Position Sensors
Maggie
Aug 16, 2024
Greenwood, South Carolina
Clueless 2G eclipse owner & new DSM member. I have a 1996 Eclipse RS, automatic trans - purchased from someone who has torn apart much of the wiring in the engine bay.
The connector for the Park/Neutral safety switch sensor has been cut off and I cannot find a replacement connector anywhere. I did find a universal connector that seems to fit/match the male part of the sensor, can I simply splice the cut wires onto a new connector? Forgive my ignorance if this is common sense.
Here is the link to the universal connector https://www.oreillyauto.com/detail/.../automotive-car-1996-mitsubishi-eclipse?pos=4
The connector for the Trans Range Position sensor is there, but the wires have been cut as well and spliced back onto the connector. I don't trust that these are even the correct wires because of the ungodly amount of splicing and un-plug connectors dangling around, can someone PLEASE show me a picture or tell me the colors of the 3 wires for both the "Park/neutral safety switch" & the "Transmission Range Sensor".
I have scoured the electrical diagram manual and I just don't see it and/or know what I'm looking at. I don't know how it's even running since the neutral safety switch isn't even connected.
Solution
A-85 Park/Neutral Position Switch
1 - Red
2 - Black w/ yellow
3 - Black w/ white
A-88 Transaxle Range Switch
1 - Black
2 - Red w/ green
3 - Yellow w/ green
Exactly what I needed. Thank you so much!!! I could kiss your face....
The manuals show they were only on 1995 models.
1 - Red
2 - Black w/ yellow
3 - Black w/ white
1 - Black
2 - Red w/ green
3 - Yellow w/ green
1 - Red
2 - Black w/ yellow
3 - Black w/ white
1 - Black
2 - Red w/ green
3 - Yellow w/ green
Solution
