2Ga front bumper question.
jey
65
Aug 7, 2002
seattle, Washington
dont know if anybodys done this before or not, but can you remove the portion of the 2Ga front bumper/grill area? im talking about the part that looks like:
-+-+-+- without cutting it? or do you have to cut it off at the top and bottom ends to remove it?
-jey:thumb:
If you look at the bumper I think that part is attached to the bumper and if it is then it will require you to get a dremel or some sort of cutting device and cut that part out then make sure you can't really notice from afar and you're set.
If you can notice then just figure out the paint code and run go get some paint to match or get a bodyshop to give you a small amount if they will.
Goodluck.
Yeah you would probably have to cut it...If I were you...I would just get a 97-99 factory bumber...they seem to look the best. One of my friends cut up, painted, meshed, etc. his 96 front and ended up getting a 98 bumper becuase whatever he did...he just didnt like the way the 95-96 bumper looked. Good luck in whatever you decide to do.
Chris
