2g won't start - no fuel, no spark
gsx_eclipse99
Nov 11, 2012
Royersford, Pennsylvania
Okay so I've had this problem for months now. At first, my 2g gradually started to sputter out. When I would give it gas it would not move and just sputter when cold. I ignored it for a couple weeks until my car would literally not move when I gave it gas. It would just sputter out and stall. I've tried a lot of things to try and fix the problem, and now I'm not getting fuel OR spark so the car won't even start! I don't know what else to try. Any tips or suggestions would be much appreciated, thanks!
Things I've tried/replaced/ruled out since issue:
ecu, wiring harness, fuel pump, plugs/wires, coolant temp sensor, cas, map sensor, maf, fpr, no boost leaks, coil pack, and the IAC.
hey i have a 95 eclipse RS and my clutch wont go shift my car? some reason when my car is on it wont go into gear so i have to start it in 1st gear to go and after that it shifts but the clutch still doesnt work and id have to turn my car off at a red light or something if i had to stop and then restart car it sucks... it just happened 3 days ago... havnt driven it since dont want to wreck anything just need advise ! please help very much appreciated
holy thead-jack batman!
I recommend starting your own thread.
